Log in
Who is online?
In total there are 90 users online :: 10 Registered, 0 Hidden and 80 Guests :: 2 Botsaleksandrnod, bomaderry, cntrby, Geekman, lihediruc, noahwinter357, nostrx, para16, Rabid1, rhondagraham27
Most users ever online was 481 on Sun Dec 25, 2011 9:42 pm
Statistics
We have 35642 registered usersThe newest registered user is tristanseth1234
Our users have posted a total of 26252 messages in 4183 subjects
Top posters
| tipstir (6069) | ||||
| arcmatter (1093) | ||||
| bayman (836) | ||||
| chicle (774) | ||||
| ExMORTIUS (753) | ||||
| b33zudroid (619) | ||||
| Rabid1 (513) | ||||
| Daisimae (361) | ||||
| jnewt74 (337) | ||||
| wilberfish (299) |
Top posting users this week
| tipstir | ||||
| azkaalarifi | ||||
| Rabid1 | ||||
| doktorspin | ||||
| bayman | ||||
| rtesky2012 | ||||
| mutania | ||||
| juliani | ||||
| B Ogbrush | ||||
| TheKrell |
Top posting users this month
| tipstir | ||||
| Rabid1 | ||||
| mutania | ||||
| F1USGP | ||||
| TonyFFH | ||||
| gaton | ||||
| azkaalarifi | ||||
| doktorspin | ||||
| gti16vman | ||||
| bayman |
Search
Social bookmarking
Bookmark and share the address of Android Tablet Zone on your social bookmarking website
Bookmark and share the address of ANDROID TABLET ZONE - ATZ on your social bookmarking website
External Switch (Why would you use one with a Wired or Wireless Router)
ANDROID TABLET ZONE - ATZ :: ATZ FORUMS - ANDROID TABLET SUPPORT :: Android Tablet Networking :: SWITCHES
Page 1 of 1 • Share •
The router is designed to handle packets the data being sent in bits to and from. The reason to use the external switch was to balance the load. The router can only handle so many packets, VPN tunnels, BT connections, downloading, uploading. streaming large media files, VOIP, TVOIP, gaming an etc.
Here comes the external switch is like a mini computer which is has speed data transfer as does the router switch ports does, but think of this device as helper. It can take over the job to manage 10/100/1000 devices.
For each port on the router, think of it as a live network drop connection.
1 = drop direct line to 100mb/s wired devices
2 = drop direct line to (wireless g access points)
3 = drop direct line wireless n access points for 300mb/s)
4 = drop direct line to 10000mb/s devices
Now drop direct line would be Ethernet cable cat 5e
Each would go into an external switch dedicated to 100, wireless access point g54, wired 1000mb/s or wireless access point n150, n300, n450.
To get better throughput it's better to use the external switch to not to allow degradation or very low MS lag as when one PC1, PC2, PC3, PC4, PC5, PC6, PC7, PC8, PC9, PC10 all try to communicate in packets to each other or to send data to network printers. From the time you press print the printer should begin printing unless it was in the sleep so it would have to warm-up first.
The performance of the switch will depend on the packet memory buffer size their are also TX/RX buffers ususally smaller. Some switches have 1GB, 2GB data sizes. I am talking about unmanaged switches are set to full-duplex to operate at full speed ahead. managed switches you have to control the port speed. 10, 100, 1000 full, half, closed, open. That's how it's done at corporate companies. Those that outsource there IT department have these vendors that control the ports and charge you for using them. Charge for turn them on and off and daily usage. It's big money that goes on behind those ports at your job or the jack box under the desk or on the desk wall.
If you start added your own switches to the ports near your desk it can degrade the domain network that way too. The way everything should be done is from the router.
The router of prior years just had one port coming out and that's pretty much was the idea back then to use a switch to extend the range and devices. Today my network has grown and will get larger as my needs require it. Below is what I had design at work just a doodle of what I had going on here. Still most of what you'll see is in use today. Some are not.
The router is small and limited RAM in this case 16MB does get used up very quickly. Most prefer 32MB and 64MB larger packet buffers also. So the usage of the switch helps maintain the network data flow smoothly. If one of those ports go bad on the switch you can fallback to another port. If that was on the main router a bad port then you're down from 4 to 3.
But anyway the switches provide users and clients:
Extra memory buffers: Eliminates the need for external buffer memory while maintaining high peak load performance
Ensures maximum data throughput in highly loaded networks
Optimizes network performance (digital streaming A/V, VOIP, POE, IPTV an etc..
8K mac address stores a large amount of stations at wired speed Gig switches has Jumbo Frames
Similar topics» definisi router
» External Switch (Why would you use one with a Wired or Wireless Router)
» Craig CMP 738a ROM MOD
» port based vlan switch recommendation needed
» Help!!! Wireless Not Responding
» KTZMOD - Today's Released of IC4 MSX GS 160 MOD Patch for 7015/7015A
» help firmware table china
» Almost Completed is the ICS 4.0.4+ Bulldog Blue Master Elite A100 ROM Update for Skypad Alpha2
» It's really almost done with ICS 4.0.4 Bulldog Titanium T100 with ECON 20 for KTZ Kyros MID7042
» ATZMOD - BETA 2 MOD TEST PATCH 11.zz.11
» debugging usb for synet7lp
» firmware for arm926ej-s rev 5 v5l
» Almost Completed is the GB 2.3.4 Bulldog Black Master Elite C90 ECON 10 ROM Update for Visual Connect & Prestige
» WM8505 hardware, rom updating, touchscreen and google market
» Dead aPad only booting logo
» KTZ SUBSCRIBERS & CONTRIBUTORS - BULLDOG GOLD MASTER LITE T80 (256MB) OR T81(512MB) 5.7.12
» Updating SYNET7LP android
» KTZ SUBSCRIBERS & CONTRIBUTORS - BULLDOG GOLD MASTER ELITE T80 (256MB) NON HD | HD T81 (512MB) 5.7.12
» Update WMT 2.1.2_105 help????!!??? :(
» NEW! RELEASE BULLDOG BLUE MASTER ELITE A80 5.7.12
» Bulldog Blue Master Elite A90 ECON 10 5.16.12 for ALPHA2 running Gingerbread OS 2.3.4
» Android Market 3.4.4
» HONEYCOMB ROM MOD FOR EPAD & MAYLONG
